telejed
- 2:10 PM
- Oct 19, 2020
- Godfrey Illinois
I don't know much when it comes to this stuff. . . I'm really just trying to get some "rules of thumb" to get started grinding on my own. However, the short blow down/long duration part. . . are you sure?I could maybe see excessive blowdown causing a short circuit to the scavenge loop. Especially with an open muffler and wide exhaust. Can’t say I’ve ever seen it though.
How much does the flow rate out the exhaust change related to transfers opening?
But yeah, SHORT blowdown could overfill the chamber if the transfer duration is long. I don’t see a performance problem there, just fuel economy. I’ve always tried to fill the chamber with 100% fresh charge. I’d rather some fresh fuel go out the can than have spent exhaust remain in the chamber.
Here is another wrinkle in all of this. . .
The maximum charge volume you can get into the combustion chamber is limited to the volume change under the piston from TDC to BDC. The only time that I know that you can actually count on that volume is a saw with reed valves on the intake. Most saws that are in production or are relatively easy to get parts for and keep running don't have those (at least for what I know).
Hey, I'm just trying to figure out if I'm even playing the same game to be in the same ballpark about this stuff.
