junkman
Crush it
- 2:44 PM
- Jan 3, 2016
- pacific northwest
Gotta love peer pressure ,lol
So what your saying is that it's just like the rest of Daves saws?I'll be bringing Daves, but it has 0 time on it.
Tank still smells like plastic
Cannot confirm nor denySo what your saying is that it's just like the rest of Daves saws?![]()
An E bar is half a pound lighter than an ES? Interesting. They're both laminated, correct? Only difference is RSN?If you are going to use a saw for limbing, getting the weight down is just as important as improving performance, and I reduced the weight of the MS440 by almost 3/4 of a pound, and all of it from the front of the saw which will also improve the balance!
The Huztl dp muffler is 2.3 oz lighter than the stock muffler, and since it is well vented I also removed to heat shield (saving another 1.1 oz). I then replaced the 20" ES bar with a 20 " E bar, saving another 8.3 oz. Total wt saving: 11.7 oz, or almost 3/4 of a pound.
If you are using the saw for limbing for a prolonged period of time, you will notice that difference.
After putting the B&C on it, I did a few test cuts with it. I think I'm gonna like this saw! Will know better when I compare it to my 044#1 in the same wood.
E bar is much lighter, basically a homeowner laminated bar. I use the 18" E bar on my 361 to block down bigger stuff, just because of the light weight.An E bar is half a pound lighter than an ES? Interesting. They're both laminated, correct? Only difference is RSN?
