MS460 Teardown-Comments Welcome
Moparmyway
Its just a saw
6:10 AM
In a meeting
Angelo, the little bungee holds the cylinder (which is over the rings) and piston up while I apply the gasket maker to the base. I start the cylinder over the piston before I apply the gasket maker, and I'm working on it alone.
Dan, I used the 51817 again, just made sure I sanded and cleaned with carb cleaner so it should stick better this time. Fingers crossed.
Mike, a little practice and you will be able to coat the base then slide it over the rings, no bungee necessary
angelo c
Coal Member
6:10 AM
Ok now I understand the reasoning....but....the only time a jug is "easily" placed over a piston is when there are no rings. Like when measuring squish ect. The rings provided enough resistance where I've never needed anything to hold it up. I usually have to rock and screw the jug over the piston with moderate effort. As opposed to being weary of it falling. But whatever port in a storm ...will get you home.
6:10 AM
Damn it Jeremy, YOU WIN THE PRIZE!!!!!!
After putting the cylinder back down, I assembled the saw, and it still would not start. So based on all the comments, I replaced the coil. When I saw fuel coming out the muffler, and I still did not get a pop, I had to just put it down and walk away for a while. As I thought on it, Jeremy's comment seemed like the only logical answer.
When I pulled the flywheel nut last time I must have just checked that the space between the flywheel & key was correct, but that does not mean anything. I pulled the flywheel today, and the key is sheered, and was off by almost 180 degrees.
Thanks for the advice Jeremy, at least I know what it is now and can stop going crazy!!!
6:10 AM
This saw has been the most frustrating one I have ever worked on. I was told it had a bad P&C, which did not bother me because I intended to to install the 046-D jug I got off ebay and Al ported (and I purchased a new piston for it anyway).
I was initially elated to learn there was nothing wrong with the original P&C, and I still have them on the side, but as I flushed the crank out to assemble it, I noticed the bearings were bad, so I had them replaced (you could not detect the problem till I flushed the case). I also noticed the kill switch was missing a contact. Since it is located next to the carb in a protected area, I can not even imagine how that happened!
Luckily, I was able to catch Mark in the shop today and a new flywheel nut and key will be on their way Monday.
I'm determined to have this saw up and running at the GTG on 4/24. It is tough working on a "problem case" when your time is limited.
Thankfully, the advice from the members (in this case Jeremy's) saved the day!
THANK YOU JEREMY, I SHOULD HAVE CHECKED IT MORE THOROUGHLY THE FIRST TIME!!!!!
Moparmyway
Its just a saw
6:10 AM
In a meeting
Yep
I sat a freshly rebuilt minty 034 on the shelf once because of that very same reason.
Ran for 30 seconds and quit.
Flywheel seemed "fine".
Wasn't spinning on the crank and I could see the key that appeared to be still intact.
Put a new key in it, started and ran on 2nd pull.
:campeon:
VinceGU05
one day when i grow up...
6:10 AM
S.E Australia
It never back fired while trying to start it? I have had a few saws with key way issues and they usually back fire when the timing is up to sheet.
Glad you found it and have it on the mend now [emoji4][emoji1360]
6:10 AM
As I previously stated, it initially started, ran very rough, then died and would not start again. I thought it was a carb or air leak problem.
Never kicked after that, timing must have been too far off.
6:10 AM
It just dawned on me that I've got a MS440 parts saw. Anyone know if the flywheel nut and crank key are the same on the 440 as on the 460???
6:10 AM
Before I get myself into trouble tying to do it, anyone want to share any tips on separating the cylinder from the piston on a fried saw?
Are they usually "stuck" or do they usually just come apart?
I acquired two saws right before tax season that had fried P&Cs, and working on them will be another 1st for me.
Boy, I'm gettin to be a pain in the A$$, aren't I???
