MS460 Teardown-Comments Welcome
Landmark
Chainsaw Hack
8:57 PM
WNC
Moves free by hand and seems to bubble out the oiler hole like it should work
8:57 PM
The 084 oiler I worked on this winter was seized. Took it apart and it looked spotless. Had to grab the drive with vise grips to get it freed up. 20 years worth of bar oil had gummed it up enough to spin the drive tang on the plastic gear and ruin it. Had to actually clean the piston and walls to get the gum out. Almost like cosmoline inside.
paragonbuilder
8:57 PM
Norwich, CT
I had a poulan 4400 that was bubbling air out of the oiler. Almost no oil. Turned out it was sucking air from an end seal. I'm not sure how similar it is to a 460 oiler but check out this thread
Poulan 4400 oiler
http://opeforum.com/index.php?threads/Poulan-4400-oiler.1715/
Landmark
Chainsaw Hack
8:57 PM
WNC
Ok i filled oil tanm up with diesel and ran the saw. None ever came out of the oil hole. When i revved the saw up it peed out the vent. What should i try next. Another oiler? Btw local stihl dealer priced me an oiler for 101.00. So new from them is not an option.
paragonbuilder
8:57 PM
Norwich, CT
The way I found my problem was I removed the oiler and the hose to the tank. I put the oil line in some oil and spun the pump gear by hand. This will test just the pump, not the drive mechanism.
Landmark
Chainsaw Hack
8:57 PM
WNC
Ok just tried that. All i ever got it to do it burp a bubble or two. Never even a drop of oil.
