- 12:36 PM
- Feb 23, 2023
- Montana
It's looking good Cowboy.Nice that you took the time...to time it. Haha. Interesting numbers. Shortest intake duration I've seen on a saw.
That would be an interesting comparison. I want one too. Figure with all the 50,51 and 55s out there should be a fun saw to port, test, swap cylinders etc....for scientific purposes of coarseThank you! It's definitely a lot better than it was.
There's a lot of room to improve the port timing. If the base was cut to get the squish where it should be. Then there would be more room to work with.
It makes me want to buy one just to do it and compare it to this one.
Open'er up!Let me to the exhaust side of the cylinder and remove the muffler. Just two nuts and off it comes. Again, *cough* it's a 5/16 socket.
The two exhaust bolts just slip into a Grove in the cylinder. Simple and cheap.
Well that side of the cylinder is stripped.
What say y'all? Looks like this muffler could use a little help in the breathing department. It's sad how choked these thing are from the factory. But,it give boys a reason to mod their toys.
I opened one 50s muffler and tried it on three saws. Only increased noise, that is only one science test.
There was a muff recall early on. Went to dealer, he did not know. Went in office, came back said sure enough and wanted my old one in exchange. We did not at all get along afterwards and I never traded, so do not know the difference.
That would be an interesting comparison. I want one too. Figure with all the 50,51 and 55s out there should be a fun saw to port, test, swap cylinders etc....for scientific purposes of coarse![]()
Wish I could, not my saw and I was given orders not to.Open'er up!
Okay, did your muffler look like the one on this saw?Muffler has an L shaped baffle.
I enlarged the holes, the exit, and deflector.
If it had helped I would have went bigger.
There is talk on here of the 50 choke but I can not find it.
Thank you.Was not trying to make a point just trying to contribute.
Though I have not confirmed it. I've read in several threads the 44mm 50, 45mm 51 and 46mm 55 cylinders have the same bolt pattern and are interchangeable(all share the same stroke) The 50 special was a 45mm closed port....Hyway also makes a 46 mm closed port....Yes indeed, there's definitely room for improvement. There's a couple.things I don't like. First, is the open transfers.
There's options for a better cylinder. Nice! I'm sure a carb swap could be done and the appropriate linkage added to get rid of the current choke.Though I have not confirmed it. I've read in several threads the 44mm 50, 45mm 51 and 46mm 55 cylinders have the same bolt pattern and are interchangeable(all share the same stroke) The 50 special was a 45mm closed port....Hyway also makes a 46 mm closed port....
