Husqvarna 564xp porting
Tomos770
4:20 AM
Slovenija
It doesn't matter. Port finish has no effect on unsteady gas flow in a duct. This is because the area next to the surface sees little movement.
The only port I want with a fine finish is the exhaust port for the purpose of limiting carbon buildup.
The piston is no doubt on the heavy side. Strato pistons always are.
I do wish it had a Mahle cylinder.
Wonder what changes AI + supercomputer driven future will bring to the table....
hacskaroly
2100 Fanclub Member
7:20 PM
Northern Idaho, Ehh
Wonder what changes AI + supercomputer driven futer will bring to the table....
There will probably be another article which will be titled: "Frontier supercomputer uncovers why worn chainsaw chains aren't as efficient" - "Scientist have used the Frontier supercomputer to find how microscopic cutter damage cuts chainsaw chain efficiency and durability..."
jurchybald
4:20 AM
Slovenia
After running my ported 564xp for a week there is not much wrong I can say about it. Ergonomically is in the class of its own. It's way more powerful than 562xp. Efi gives it instant throttle respond and muff modded is not that loud. Comparing it to 400.1 is ridiculous in every espect except build quality.
bwalker
10:20 PM
Montana
Sonyour thinking its superior to a 400.1? Care to go into that in detail?
Jake Dykstra
7:20 PM
NW Washington
I dont have a 400.1 but I have an Eathan Trainer ported 400! Its pretty dang strong. Not sure if my 564 can keep up. Only one way to find out!
ZERO
Simple Life
4:20 AM
Woods & Mountains
Nice work Sir.
Let us know how you like it long term after break in.
jurchybald
4:20 AM
Slovenia
IMHO it is much better saw for daily use. Antivibration system is near perfect. It seats in my hands like a violin. I'm much more precise on stump than I was with 562xp. It has more power than 401 and it starts every time. Something I cannot say for 401. And damn thing vibrates like crazy.
Nevertheless it is build like all 5 series husky. Chinese bearings, gilardoni cylinder that you just look at and it's flaking off. We'll see how long can it takes the beating we are giving it
Tor R
Novice, Leg model #2
4:20 AM
Mandal
Hqw yes. You are right. It's german brand. I saw nylon cage and think china..
Composite materials can be very strong, and withstand high temperatures, and unlike metal, can have less material dimensional change in temperature changes.
In terms of appearance, it looks more like a peek than anything else, it must have been closer to 7-8 years since they changed it.
jurchybald
4:20 AM
Slovenia
Had some time today and tested cutting speed with same bar and chain. Stihl was actually little faster. But it's a vibrator comparing it to husky. And I did only 2 huskies so far.
