Tomos770
- 8:04 AM
- Mar 20, 2022
- Slovenija
Wonder what changes AI + supercomputer driven future will bring to the table....It doesn't matter. Port finish has no effect on unsteady gas flow in a duct. This is because the area next to the surface sees little movement.
The only port I want with a fine finish is the exhaust port for the purpose of limiting carbon buildup.
The piston is no doubt on the heavy side. Strato pistons always are.
I do wish it had a Mahle cylinder.
Frontier supercomputer uncovers why worn turbine blades drain jet fuel
Scientists have used the Frontier supercomputer to find how microscopic turbine blade damage cuts jet engine efficiency and durability.
