Husqvarna 564xp porting
Sloughfoot
3:12 AM
Norcal
Hey, first impression is good. Easy to work on fired up after 4 pulls in -10celsius. Feel like Husqvarna is at least trying to make a great product here. Was as i said a little coarse casting in transfer, exhaust and stratoes. And plating flakes off easy.Feels very strong in 10inch seasoned oak. The owner is on firewood duty these days so expect he will tell soon.
Did you do do anything to it other than porting the cylinder?
Sloughfoot
3:12 AM
Norcal
I don’t see that as being acceptable, but I suppose some porting techniques may be more likely to flake the plating.
Some cylinders will flake no matter how careful you are and some you couldn't get to flake if you tried. Later model Huskies are getting a bad reputation for it.
jurchybald
12:12 PM
Slovenia
What was the gain with porting you did? I tried stock 564 and my ported 400.1 feels much stronger.
CapitaineHaddoc
I don't eat frogs
12:12 PM
FRANCE
Removed base gasket. And opened up the original outlet in the muffler.
Careful. Deleting the gasket with your numbers seems tight.
0.85-0-5 = 0.35mm. That's "0.014. I plan to make my own gasket with oiled paper on my 564, I have 0.15 and 0.25mm thickness.
Kongpils
12:12 PM
Norway
Feels stronger than a stock one for sure.
And im sure there is more left on the table to gain also. Once the many brilliant chainsaw guys in here plays a little with one.
Jake Dykstra
3:12 AM
NW Washington
I think my 564 order was the first one ordered as soon as it could be done. Hoping that means I'll see it soon!
My buddy ordered at same time so ill have a stocker to compare to and can start hacking away at mine
qurotro
Cookie Cutter
5:12 AM
Ar
Nice pics! Thanks for posting. But where is the injector?? I'm so curious about that.
Jamie D
Active OPE Member
8:12 PM
There to the left. Then the throttle body mounts onto this again.
Plan is to delete base gasket, port to Ex:100 Tr:115 In:78.
If it runs bad i can lover the jug and put som epoxy in intake.
Some rough casting.
And the plating can flake so be careful when somebody tinkers with theese.
How does the plating look at the squish band does it stop short? (Ring of death)
Tor R
Novice, Leg model #2
12:12 PM
Mandal
That's the million dollar question with Gilardoni jugs, I only hear negative things about them.
