- 10:34 PM
- Jan 14, 2016
- North western Ohio
Those cast iron Marvel Schebler carbs are pretty simple but they can have their moments .Needle float valve gets stuck then you have to give them a thump or two to free it up then it may not do it again for a couple of months . Old funky gas will cause you fits and if water gets in them long enough you have to deal with the rust .I boil them in a coffee can with strong detergent
for a couple of hours which usually cures them then run a torch tip wire though the passages .
When I rebuilt the carb for "Ollie" my OC 6 crawler I put the entire kit in it including running a tap through all the jet holes .BTW the main jet is 1/4" 40 TPI .It had the shaft with the bushings but I didn't need to change them .At the moment though I have no idea which tool box they are in .
