RockySawz11
OPE Member
- 12:21 PM
- Mar 11, 2018
- alberta canada
hello guys,
i've been reading and studying a lot on OPE and have learned truck loads of great info!
here's my problem ... ics 613gc concrete chainsaw. it is a 80cc powerhead with a 14" diamond chain. it does not run. it does not cough. it does nothing! it was not running when it was dropped off.
i have ... drained old fuel ... replaced in tank fuel filter ... inspected fuel inlet line and is ok ... replaced spark plug and have confirmed good spark by grounding plug to cyl. head ... i have tried champion plug and ngk plug, both new, both correct type, both correct gap ... flywheel and key are ok ... cyl. compression is 125-130psi. ... exhaust is clear with no heavy carbon deposits ... walbro wj104 carb rebuild kit installed ... carb is clean as a whistle.
i have ... removed cyl. head and confirmed that there is no scoring on cyl. walls ... rings look fine ... i swapped top ring to the bottom and bottom to the top ... piston is ok ... new cyl. base gasket. ... decompression valve is plugged.
i can pull the recoil start ### times and the thing never coughs, sputters, nothing! i thought i had flooded it ... drained fuel, pulled plug, removed carb and set it on its side in front of a diesel heater for 3 hrs. to dry it out. i have shot a bit of carb cleaner directly in the head through the spark plug hole and cranked and cranked ... no cough, no chug, no nothing!
any ideas?
SD
any ideas?
SD
