Larry B
- 5:28 PM
- Sep 2, 2017
- SW ohio
Since you have the head off if you can drop the pan easily you can remove a main bearing cap and look at the backside of the bearing insert and see if it has something like std or 010 or 020 stamped in it. If there is no stamping it is probably original standard bearings. You can also use a vernier caliper across the journal measuring up against the block. A little technique sensitive but works.
