Well the coil was a no go.
Aftermarket one was completely wrong, matched the pic but didn't match the saw it was supposed to be off of.
The 330 coil was mounted 180* off, upside down, wires wouldn't clear. So I swapped the a/m coil onto the 330 laminations, doing so I had to rotate it. Pita swapping the laminate cores.
Got it all mounted on, gapped everything.......
And nothing
either I jacked the internals on the coil, while pounding/prying the laminations out. Or I am 180* off time because I had to flip the coil upside down.
When I get some more time, I will pull the key and try 180, if I don't get at least a pop. I'm calling it done.
