Axes and associated items
4:31 AM
Skinny there on the left is getting loose on her handle…what say ye axeperts? I have sunk the wedge deeper a couple times. I was gonna wiggle the head up a little, sand the shelf out, and try to sink the head deeper on the handle.
I make a steel wedge out of flat steel, hammer it in till the handle starts "ringing", then secure it by drilling a hole through it (ax head already has a hole in it for just this purpose) and drive a nail through it.
Works PERFECT, handle will break before You're ever gonna loose that wedge!
Any other way of securing my ax head to the handle always failed.
Keep Your ax/handle dry, water will make the wood expand then retract upon drying resulting in an increasingly looser ax head.
Gullet
9:31 PM
Arkansas
Wilhelm mentioned earlier how skinny double bits are & that they are only good for felling, so I mic'd a nice convex cheek Woodslasher single bit (3.5#), and a Kelly Perfect DB (3.5#) at their widest points & the single bit was only .02" wider.
I dont personally use a DB, but I might start!
Seems like the most versatile axe.
I may break out the 4# Flint Edge & try some splitting with it before too long.
It may be the ideal camp axe.
4:31 AM
I don't believe these qualify as "skinny"
Well ................... maybe 2 of them do
Still, the ax heads look skinny, maul & maul/ax hybrids have checks.
Axes and mauls are two different breeds.
I have some axes to post, but not tonight!
11 pm for me.
Moparmyway
Its just a saw
10:31 PM
In a meeting
How's the Vario work for ya? Do you have issues with the bolts loosening? They look like splitting beasts, but the bolt thing makes me leary.
She’s new, but I checked the bolts and they are pretty tight. To me, at least if they do start to loosen, a little loctite and muscle will put everything back where it belongs
maulhead
8:31 PM
Home
What is that fancy one on the far right of the picture with the bolted-on head?
Gullet
9:31 PM
Arkansas
IMHO, it looks like A LOT stronger connection than a handle wedged thru an eye.
Cant go wrong with Helko, a proven design I'm sure.
Loony661
462’s 4-LIFE
9:31 PM
Winona County, MN
Thanks!
Ketchup
Epoxy member
8:31 PM
Colorado
Anybody got a recommendation for a proper wide blade felling axe? Mostly for notching large trees.
