Anyone else break there saws in with a rich oil mix
12:15 AM
I havent found any better and Ive used a bunch. Hadnt tried VP
Stihl ultra husky premium valvoline quarts blue bottle echo grey and red armor penzoil boat oil supertech wal mart are the only local oils i can get 12.95 per 6 pack 2.5 gallon per bottle red armor is the cheapest premium oil i can buy.
bikemike
11:15 PM
Cottage grove mn
32.1 first tank or 2 then 50.1 with amsoil Saber or 40.1 echo powerblend
11:15 PM
Is this the new oil thread I can find.the other one
bwalker
12:15 AM
Montana
Heat cycling,taking it easy, using a break in oil or a special break in ratio is ridiculous IMO.
The best way to break a two cycle in is to bring the motor up to temp on the mix and ratio you plan to run and then load the snot out of it.
Ball and roller bearings as found in two strokes do not require break in. The cylinder to piston ring interface does and this doesn't happen without a high load.
If you fart around and don't seat the rings relatively soon the cross hatch peaks wear down/fold over and the rings never seat like they should.
junkman
Crush it
9:15 PM
pacific northwest
Seems the saws dont need break in like a bike,once the bearings free up they seem to be broke in ,15 tanks or so in my experience.cylinders dont need the heat cycles like water cooled 2 strokes also.
bwalker
12:15 AM
Montana
Bikes don't need that crap either. There is basicly no differance in the bearing designs or materials used in making a bike engine vs a saw engine.
Moparmyway
Its just a saw
12:15 AM
In a meeting
Heat cycles are prudominantly in place for work hardening of bearings ............ specifically flat bearings;
like main bearings, connecting rod bearings, and cam bearings
junkman
Crush it
9:15 PM
pacific northwest
What about the older atv jugs that were boreable ? no nikasil coating in those .
