Another chainsaw dyno...
Dieselshawn
3:25 PM
Southern Ontario, canada
My MS260 with the large carb will run on 92 octane gas but the saw will almost always act like a dog that sneezes on their food and pees on it if they don’t like it. :facepalm:
That gas ends up being fed to my 1968 JD 140 lawn tractor which will run even on stale gas. :rolleyes:
So I’ve continued to run 87 gas since for all my saws. :cool:
3:25 PM
I run High Test (93 Octane) in my saws, and always mix it as soon as I get it. 2 cycle oil stabilizes the fuel.
The Stihl manual says that High Test fuel runs cooler, so I run it.
CR888
5:25 AM
Australia
I think the older gas gets... say maybe a couple weeks to a month old... the saws seem to make less power, start worse and run worse. I haven’t done any tests... but it seems so. Would be interesting to dyno test that theory. Fuel age/quality... it seems to matter. I’ll take fresh 87 over weeks old 93 octane... especially if it’s pump gas. The canned fuels seem to be more stable and deteriorate at a slower rate. Just a few observations I have made.
This is how I look at it....think of gasoline fuel like soda water. When it's fresh you can shake the bottle and it'll create pressure but when it gets stale and left open it goes flat. Well gas is exactly the same in a way, fresh gas has a high RVP (Reed Vapour Pressure) which can be measured. The higher the RVP, the more volatile it is. As it ages it looses it's RVP, like soda looses it's fizz and becomes less volatile. The more stale gas is the less power it can produce. I get fresh 87 pump gas twice a week for my saws, don't use stabiliser, don't run hi octane and find that best. Fresh gas is way better than hi octane stale gas. But racers often test the RVP of their gas, I don't but trust if it's bought fresh from a high volume supplier you should be ok. And remember, gas starts losing its volatility the second it loaded onto the truck from the refinery. Some racing nuts will source their gas from the first delivery point from the refinery rather than the last, but that's a bit over the top IMO for cutting up trees lol.
CR888
5:25 AM
Australia
Why use stabiliser if using fresh fuel. Look how stabiliser works...it's similar or likely alcohol that absorbs water. Horrible stuff if you don't absolutely NEED it. If you can source fresh gas, that's what your best off using.
