372xpw g... :)
junkman
Crush it
10:15 AM
pacific northwest
the flywheel alone is $150 ...
right now, this hobby sucks
I used to bring saws back from the dead ,but got carried away being a psp ,replacing almost everything with new ,i ended up being several hunderd more than a new saw would cost ,yes can be an expensive hobby .
psuiewalsh
Basement Bodging
1:15 PM
Nottingham,pa
Sounds like you need a Canadian friend.
Sent from my XT1585 using Tapatalk
Mattyo
Youtube speciawist
1:15 PM
Farmington, CT
I have a friend in vermont... dunno if he can hook me up with one of these ... :(
oh well, i'll split the diff w/ the customer and take the hit... time to move on
Tor R
Novice, Leg model #2
7:15 PM
Mandal
Next problem...the heated flywheel grenaded....pieces of magnet all over inside saw.
could there be several type G flywheel to 372?
Never seen a grenaded G flywheel on any of my G saws, almost think there is different generator flywheel versions to 372 now
Mattyo
Youtube speciawist
1:15 PM
Farmington, CT
Pieces of the magnet sheared off...no idea why..
RIDE-RED 350r
1:15 PM
Blossvale NY
I wouldn't think that fuel mixing with the bar oil would turn the oil milky like that, just thin it down. In my experience, milky oil is usually an indicator of water contamination. And more importantly, it's usually in oil that is agitated by a pump of some sort that gets milky with water contamination... But where did the water come from in the first place?????
If it happens again, I would dump the milky oil into a clear glass and let it settle. That will confirm whether or not it is in fact water contamination. Only trouble is that it would likely take a few days for it to settle out from a milky state. And being that it is a customer saw you probably don't have days to waste.
Mattyo
Youtube speciawist
1:15 PM
Farmington, CT
i may have used some oil out of an unknown container for testing purposes... so who knows...
and yes, i don't have lots of time here, i've already lost money, so its time to cut my losses.....
Mattyo
Youtube speciawist
1:15 PM
Farmington, CT
out of sheer curiosity, anyone know of a source for just the magnet? its circular in shape, seems like if I found one I could epoxy it in
Mattyo
Youtube speciawist
1:15 PM
Farmington, CT
or, how about some small round neo magnets... I have a bunch of those... could drill out the flywheel and add a few and jb weld them in....
hseII
Heef
1:15 PM
West Georgia
I read somewhere there is a fuel cap that is vented for a husky to get rid of the dreaded bog they sometimes have ,not sure the part # ,I think it is a fairly common thing .
I have seen that too: not sure where to get the new cap, but I do know what the fix is.
psuiewalsh
Basement Bodging
1:15 PM
Nottingham,pa
503828004. Is the cap number. My dealer had them in stock.
Tor R
7:15 PM
Mandal
you have some choices to do, but I would never done a cheap magneto modd on an 750$ saw.
I dont say you should buy a new flywheel, prices on them are ridicilous.
I said I've never seen a fragmented G flywheel, but I've seen one when I thought through those projects I had, 357xpg.
Reason was crank bearing movement, worn out bearings, it seems there is very little tolerance from generator screws to flywheel, wouldnt surprise me if that issue count for all those 3xx a saws.
What year is your crankcase&crank?
And what number do your flywheel has?
Sty57
12:15 PM
Land of Cheese & Beer
It seems the flywheel was upgraded over the years but in general all those 362&265&372's share same flywheel
Also the 385 and 390 use the same Flywheel and all of the equivocal J-Reds.
There looks like there where three different Flywheels over the period of time.
Tor R
7:15 PM
Mandal
I think you are spot on.
I've seen two different 362/372 flywheel from 99 to 05, but I can't remember who was who :) one of them had different cooling fins, it may have been 372 00.
Sty57
12:15 PM
The part I don't understand is. Looking at the IPL's they show a different Flywheel option depending on if they have the carb heaters or not.
Which make no sense to me, as the Generators are all the same.
Tor R
7:15 PM
Mandal
good point, is those two type generator same dimensions?
I thought maybe there could be different off set on those 3 type flywheel....that could at least for me make an fragmented flywheel
