372xpw g... :)
RIDE-RED 350r
11:40 AM
Blossvale NY
OK Matt, I might be confusing the way intake timing is measured... When rotating the crankshaft in the direction of normal operation from BDC, the intake begins to crack open at 75 deg after BDC... Is this correct or am I doing it wrong?? If I am correct, 75 deg would be earlier and more duration than 82?
XP_Slinger
They’re Just Saws
11:40 AM
Central NY
Intake is stated as BTDC not ABDC. For instance, say your intake opens @290° ATDC. 360° - 290° = 70° BTDC. Make sense Joe?
mdavlee
Hillbilly grinder
11:40 AM
TN
If he's going to cut the base you don't want to drop the intake much more.
Mattyo
Youtube speciawist
11:40 AM
Farmington, CT
case is already decked.... i do the port work after I establish squish.
XP_Slinger
They’re Just Saws
11:40 AM
Central NY
Nice work! Soooooo how much do you charge for this mod:)
Mattyo
Youtube speciawist
11:40 AM
Farmington, CT
This saw ...as it sits is $750. it is already sold. ported, decked, muff modded, lots of new parts, 32" GB bar and full comp chain. heated handles added, no carb element in the circuit. couldn't believe it, the heated handles do work.
Mattyo
Youtube speciawist
11:40 AM
Farmington, CT
This saw siezed in 10 minutes.
Pressure test is good with new piston...but I have a new issue.... after 1 tank...bar oil refilled....bar oil is coffee with milk brown. Opaque....ish. wtf????
Can there be a leak from the crankcase into the oil reservoir??
paragonbuilder
11:40 AM
Norwich, CT
That's weird Matt! If so it should not pass pressure and vac test though????
paragonbuilder
11:40 AM
Norwich, CT
I've never seen bar oil and gas/mix mixed...
