372xpw g... :)
Mattyo
Youtube speciawist
6:32 PM
Farmington, CT
It does not appear to be having trouble. ..but...the idle does drop when I turn the saw vertically. ...dunno if that's a case leak or not. ...if the case is leaking I'm going to be really unhappy
Mattyo
Youtube speciawist
6:32 PM
Farmington, CT
It's getting pressure from somewhere
my pressure test was good, vac too... how do I test for pressure in the oil tank.....????
pressure test again? this time w/ the oil tank full and without a cap and look for bubbles?
Mattyo
Youtube speciawist
6:32 PM
Farmington, CT
also, assuming the case is leaking at the oil tank joint, what are the odds of my case bolts being loose and being able to simply tighten them and call it a day?
6:32 PM
Could very well be a loose bolt there. Wouldn't hurt to check them. You could just run it with the cap off.
Mattyo
Youtube speciawist
6:32 PM
Farmington, CT
of interest, there is no oil leaking on the ground... zero. so at least the leak isn't towards the bottom of the case. the saw sat for a couple weeks on the shed floor, no leak. so i'm looking for a leak higher up, between the lower and upper case bolts towards the oil tank.
Mattyo
Youtube speciawist
6:32 PM
Farmington, CT
ok, just tried a simple thing, I brought the piston to bdc (more or less) and applied pressure to the impulse line... no bubbles that are dramatic in the oil tank.... gonna pop the flywheel and check the bolts
still don't know why the idle changes (goes lower) when I turn the thing vertically ... horizontal is not an issue
paragonbuilder
6:32 PM
Norwich, CT
Coffee with milk color.....not clear bar oil
That is very weird!
Have you tried mixing a small amount of bar oil and fuel mix?
If it looks like that I would split the case. No need to burn up another cylinder...
That looks like a substantial amount of mixing... What does the tree guy that ran it use for oil?
Mattyo
Youtube speciawist
6:32 PM
Farmington, CT
could be vent issue for the tip bog... who knows... if thats the case i'm not worried
water could be an issue with the color of the oil... i'll put some mix in there, then fresh oil and see what happens
I put some pressure in the impulse line, zero bubbles in the oil tank... case bolts are tight, zero movement.
junkman
Crush it
3:32 PM
pacific northwest
I read somewhere there is a fuel cap that is vented for a husky to get rid of the dreaded bog they sometimes have ,not sure the part # ,I think it is a fairly common thing .
paragonbuilder
6:32 PM
Norwich, CT
I think if it was gas, it would need to be a lot to change color like that, you could smell it like when fuel gets in engine oil.
psuiewalsh
Basement Bodging
6:32 PM
Nottingham,pa
I had an 064 that would go lean, it had a pinhole into the oil tank. Was fine until the oil got used to that level. Have you tried putting the sealed saw into a bucket of water to look for leaks?
Mattyo
Youtube speciawist
6:32 PM
Farmington, CT
No...haven't done the bucket trick.
At this point the water in the oil is the best explaination. The pressure test I did before and the pressure in the impulse line with water in the oil tank should have revealed the problem if there was one.
After 1 tank the compression is up...the plug is rich looking.... definitely not lean.
Mattyo
Youtube speciawist
6:32 PM
Farmington, CT
Well...it's not running lean...it cuts well..
Next problem...the heated flywheel grenaded....pieces of magnet all over inside saw.
Please tell me another heated flywheel is cheap
