044 hybrid build CFB style
Canadian farm boy
“Normal” people scare me.
4:39 PM
Ontario, Canada
Finished ports.
Intake is finshed with 120 grit emery cloth.
Exhaust is finished with 260 grit.
The transfers are finished with multiple shapes diamond burrs.
To do the port bevels I use a 8mm ball shaped diamond burr and some 120 grit emery cloth on my finger.
I hone the cylinder with purple scotch brite to just deglaze itIMG_6676.JPG IMG_6678.JPG IMG_6679.JPG
Canadian farm boy
4:39 PM
Ontario, Canada
New oem 046 piston kit and a new oem wrist pin bearing.
Make sure you put the gasket on before you install the piston. The 044 cylinder gasket won't fit over the 046 piston without either scratching up the piston or bending the crap out of the gasket.
Arrow towards the exhaust. Ring pins towards the intakeIMG_6684.JPG IMG_6685.JPG IMG_6686.JPG IMG_6687.JPG
Canadian farm boy
4:39 PM
Ontario, Canada
Installing the muffler.
This slick azz @Adirondackstihl designed muffler spacer is awesome!
When installing the muffler it goes heat shield, gasket then muffler.
Before tightening down the screws at the exhaust port it help to line everything up if you loosely put the lower muffler screws in.IMG_6717.JPG IMG_6718.JPG IMG_6719.JPG
