- 12:41 AM
- Dec 24, 2015
- Coastal Oregon
Just a note on post #406; two of the six holes for the crank case cover are tapped 1/4-20 so you can use your same puller to remove it. I have used the tap, tap, tap method but the puller is actually quicker and easier.
Mark
Great point Mark - but that's not always the case. None of the holes in the backing plate for this saw are tapped and a CP-125 I went through a few years ago didn't have any tapped holes in its' backing plate either.
Luckily the replacement backing plate I'm going to use in this saw does have the tapped holes and it is a Mag plate vs. the Alum plate the saw came with (the Mag plate will save several ounces of weight).
