- 4:16 AM
- Feb 23, 2023
- Montana
I can make the 661 work. It's just a matter if I can get the components around the cylinder to work. The 660 cylinder I have is not going to be used on a 40mm stroke saw, but a 38mm. I have plenty of room for the extra compression height of the 661, without cutting into the squish band and taking about 1mm off the cylinders base. Now going with the 660 big bore piston I'd have to take around 6.5mm off the cylinders base.661 won't work. Too tall and it Freeports worse.
Onto the 056 magnum and 395xp.
Ideally I'd like it if the 660 BB piston had a 2mm longer skirt.
I can see why in your case it would not work since your useing the 660 platform. You would have more that just a Freeport problem. The piston at bdc would be sticking up in the exhaust port by close to 6mm. That in itself would not be exceptable.
I still may end up using the 660 BB piston so I can lower the cylinder and have the exhaust port close to the same as the factory location, as well as the intake would line up a lot better with the factory carb location.
Time will tell.
