farminkarman
I like the red & black ones
- 12:03 AM
- Aug 17, 2020
- Neenah Wisconsin
Joe, did you leave the upper transfers alone, or did you raise them a bit? Looks great btw!
That looks pretty strong!View attachment 361847
Found a wee bit more. About as I expected, the fingers seem to add a "hit" up top. But should make a dandy 60cc firewooder.
Don't you mean 70cc? LolView attachment 361847
Make firewood faster for sure!
That’s a huge improvement! The torque curve is especially impressive.
I suffered a major setback on mine. I set it up for port work last night. Stock numbers are 76/98/112. I doubt I can drop those transfers enough. Very unhappy with the Hyway jug.
Hmmm.....
What piston/setup did you use?
064 piston. 0.040” out of the band and 0.080” off the crown put me at .025” with 2 gaskets. If I keep going with this jug I’ll take more out of the band and try a 038 magnum piston.
It has other problems though. The uppers have a lousy exit angle and the plating is flaky AF.
I’m not happy with my workmanship either. I went too fast.
Just curious, why do you think the 038 mag piston is the best?Seems the 038 piston is the way to go with these. I would happily shave another .020 off the piston starting over on this one.
I feel ya. Mine is rather rough around the edges and piles of "modified" junk left in the wake... trying to stay focused and making projects like these happen I tend to run through lots of parts trying to find the "just right" pieces.
I have had the best luck with the bottom of the barrel 20$ eBay white box kits.
I see what you mean.About the shortest pin to crown height with Windows. And keeping ok skirt width. I believe the 046 is the same height as the 38
I took .060 from the band and .010 off the piston and still had to run a gasket. Dolmar 7900 piston may save some machine work too bit rather limited skirt width. These shorter strokes need to be able to have wide ports.
460 piston has coated skirts, and 038 is bare.View attachment 361906View attachment 361907
Here is a look at an OEM 272 jug vs. a meteor:
The OEM transfers blow much harder back toward the intake than the meteor. I will probably mock mine up with the meteor first and then modify & use the OEM jug.View attachment 361910View attachment 361911View attachment 361912View attachment 361913
