Why don't more people run PS3 chain instead of 325 on 50CC saws?
Philbert
Chainsaw Enthusiast
6:27 AM
East Dakota
Oregon already has/had a .325 low profile chain. I have some discontinued yellow label 34LG low profile chisel. They still sell the 33/34/35SL low profile chisel safety chain.
Were these rally 'low profile' cutters?
They have not made those in a l-o-n-g time. Listed as 'obsolete' in 2010 Oregon guide. Not even listed in their sharpening guides anymore. https://online.flippingbook.com/view/276256/162/
Screen shot 2019-07-02 at 11.11.08 AM.png Screen shot 2019-07-02 at 11.12.35 AM.png
The 'Speed Cut Nano' uses different sprockets and bars than conventional .325 chain.
Philbert
Farmchuck
7:27 AM
Nepa
6:27 AM
Philbert
Chainsaw Enthusiast
6:27 AM
East Dakota
So would this make the speed cut nano not .325 technically?
Technically, 'pitch' really refers to the spacing of the drive links on the chain, and how they engage with the drive sprocket. '0.325 inch' pitch chain means that the tips of the drive links are 0.650 inches apart (for some reason we divide the spacing by 2 on saw chain).
Since it is hard to accurately measure the drive link tips (they wear, and move around) we measure the spacing between 3 rivets and divide by 2, but if you shift the lines over on the classic illustration below, you can see how they also align with the tips of the drive links.
So, .325 pitch chain matches .325 sprockets. But the actual cutters can be taller or shorter (low profile), wider or narrower (narrow kerf), shorter (some carving chains), or even missing (skip-tooth); and the drive link gauge can be thinner; and still fit the same drive sprocket. Same pitch.
As a practical matter, once chains require special sprockets or guide bars (e.g. narrow kerf and most low profile chains), I consider them to be a 'different' pitch chain. E.g. with 3/8 low-profile/Picco and full-sized 3/8 chain, the spacing ('pitch') is the same, but the shape of the drive links is different, requiring different sprockets.
Philbert
6:27 AM
Philbert
I always have read that 3/8s lp/ picco is .365 instead of .375. So that was making wonder after you said different sprockets is this new .325 maybe really .315 or something?
Philbert
Chainsaw Enthusiast
6:27 AM
East Dakota
3/8 low-profile and full 3/8 have the same rivet spacing:
100 feet = 1,200 inches
1,200 / 1,640 = 0.7317 inches
But since we divide by 2 (?) 0.7317/2 = 0.36585 inches. A bit short of 0.275.
Think of it as a 'nominal' measurement (e.g. '2 by 4' studs really being 1-3/4 X 3-3/4", or Subway 'foot long' sandwiches maybe not being a full 12 inches). Either way, they are the same in that regard.
Philbert
radio
7:27 AM
SoNH
Deets066
AKA Deetsey
7:27 AM
3/8 picco is not the same as regular 3/8.
That’s why they each have their own bars and sprockets.
Wonder why if picco is actually.365, then why are the drive sprockets larger than regular 3/8?
chipper1
7:27 AM
Grand Rapids Mi
That's right.
If you want a picco sprocket you have to turn a 404 down to get it the proper size.
I have all the specs somewhere and probably some pictures to, but it was from yrs ago back when guys were still talking about all the stuff lol.
Just because guys run picco on standard 3/8 sprockets and bars that doesn't make it right, take a look at them afterwards and tell me if it's right.
Philbert
Chainsaw Enthusiast
6:27 AM
East Dakota
Right. But the rivet spacing ('pitch') is the same: 3/8 inch (nominal).
They use different sprockets because the drive links are shorter, and have a different profile. 'Picco' chains do not correctly seat into a full sized 3/8 pitch sprocket, and full sized 3/8 pitch drive links are too big to fit into smaller 'Picco' sprockets. It's like a short guy and a tall guy trying to fit into pants with the same waist size but very different inseams.
They use different bars only due to the sprocket nose (otherwise, a hard nose bar could run any pitch chain of the correct gauge).
The different sprockets fit the profile of each chain. 3/8 low profile ('Picco') fitting a turned down .404 is just by chance: when you reduce the diameter of the sprocket it fits the smaller drive links, and reduces the spacing between the slots. Someone just happened to discover that it worked.
Philbert
6:27 AM
IDK I only have one saw that runs lp
Philbert
Chainsaw Enthusiast
6:27 AM
East Dakota
Yes they are real low profile. The LG was discontinued but the SL is still being sold as far as I know: http://en.oregonproducts.com/pro/products/chain/33_34_35SL.htm
Than is a European Oregon website, which still lists a lot of the older technical information that I wish the US site still did. The chain is not listed in the current Oregon Forestry catalog:
If you can still get it, that would be a find. Buy a bunch if you like it.
Philbert
radio
7:27 AM
SoNH
Philbert
The problem with the SL is that it has safety bumpers, big ones. The LG is much better.
chipper1
7:27 AM
Grand Rapids Mi
But is not needed in the sentence. I was referring to deets comments and him to yours, what was said was right, no butts about it!
Now if you wanted to say also or something on those lines that would be more "fitting".
You may want to remove this :rolleyes:.
Although I understand where you're coming from it makes no sense because you know what they are measuring and it doesn't correspond to "pitch", so you can do as you like as a practical matter, but it's not correct.
Philbert
The point I was making here is about the diameter, not the chance that it fit. Nice that it will work if needed in an application though.
Philbert
Chainsaw Enthusiast
6:27 AM
East Dakota
You may want to remove this.
Depends on how one defines and understands the term 'pitch'. (For some, it is a black, sticky substance used to patch roofs; an action of a baseball player; or even the field where sports are played).
Or buy a STIHL Rim Sprocket 00006421240 (or the equivalent).
Philbert
chipper1
7:27 AM
Grand Rapids Mi
Philbert
Really o_O.
Philbert
:rolleyes: :facepalm:
Wonkydonkey
Plastic member
12:27 PM
Sussex, UK.
Just a follow on of the pitch of a chain std 3/8 and 3/8 lopro
On another forum, there was a guy using a 660 I think. With a 3/8 lopro chain. He was milling some larch on a logsol mill. It zipped through it fast. But he got pissed when the chain kept snapping.
Here’s a pic or 2 of the chain, notice the marks highlighted by red arrows
Here’s some broken bits
It turned out this was the reason the chain had kept snapping
It’s a std 3/8 spur. It took a bit of time getting pics and piecing it all together..
I'm not sure how a rim sprocket would have behaved
Edit, I think the guy had to ditch the chain,,, even after changing to the proper size sprocket, because the chain had been weakened
chipper1
7:27 AM
Grand Rapids Mi
You may get away running 3/8 picco without the proper bar and sprocket on a low powered saw, but it will show up when there is more power and a high load situation.
Farmchuck
7:27 AM
Nepa
Philbert
Good understandable analogy!:beer-toast1:
Philbert
Chainsaw Enthusiast
6:27 AM
East Dakota
The smaller pitch chains are designed for lower powered saws, so they use thinner, lighter components (tie straps, rivets, etc.). For example, Oregon only recommends their Type 91 (3/8 low profile) chain up to 40cc and 18" bars in some of their literature. I have certainly seen it on larger saws, but you can see where a 660 could snap it.
Philbert
