Deets066
AKA Deetsey
7:28 AM
here is theory saws that use oil that have a lower viscosity and flash point will make better power than other oils that have a higher viscosity and flash point. as the oil that is burning with the gasoline will produce more BTU's than the other other that is not being burnt and left behind in the engine.
that is the way my little pea size brain understands this.
That's one way to look at it.
I look at it as a "good" oil will have more viscosity will have less piston and bearing wear. It will also provide a better seal with the rings, which means more compression and no blow by.
Less viscosity cheaper oil with lower flash point may burn hotter but may have some blow by. Black carbon burnt past the rings. Which means your not burning all the fuel you transferred from the case
Keith Gandy
Maxima K2 40:1 87 Pump Gas
6:28 AM
Provencal, Louisiana
Heres a question I have wondered about. Does a clean piston top offer an advantage over one with carbon on top? Does carbon on top of the piston keep the piston from absorbing as much heat or does the piston need to absorb the heat to transfer it to the cylinder and fins?
Moparmyway
Its just a saw
7:28 AM
In a meeting
Its my 661 after running about a dozen tanks of my 50/50 mix (R50 & 800) with VP 94 SEF @ 25:1 with the WJ69 and standard coil tuned to 13,750
The squish is just about spotless except for a shadow on each side of the exhaust port
The crown is all carbon except slight transferr wash
According to some theories floating around, the excess Oil at 25:1 should have kept the crown spotless.
I've learned alot from Ben, Mike, and Jason ......... I'll just stick with my "exotic" non ethanol fuel and see how the different Klotz oils perform and smell.
Moparmyway
Its just a saw
7:28 AM
In a meeting
IMHO, rings are where dudes need to be concerned. If there is carbon in the rings or lands, you've got to address something. Carbon in the chamber and on the crown is what's necessary for good combustion
Keith Gandy
6:28 AM
Kevin I cant tell if the piston has carbon or not? Is the top all carbon except wash marks?
Moparmyway
Its just a saw
7:28 AM
In a meeting
Keith Gandy
6:28 AM
800t with 87 efree at 32to1 in a ported 461 tuned to 14600 to 14800 loaded with a 28" bar. Looks to be combusting but there was more carbon but I wiped it before the picture as some came offmoments_10202729527759872.jpg
Keith Gandy
6:28 AM
I believe the lower octane will produce less wash marks. I dont know that for sure but I switched to 93 efree and alil techron in my mix and ill compare to the pics in my hybrid with 87efree
Ron660
6:28 AM
NW Louisiana
Ok question here ,a hopped up bad ass chainsaw that scares women and children when it is started may have 230 psi for example ,i bet it still does not have more than 8 to 1 compresion which 87 octane would be fine for ,the 110 race cas burns too cool making wasted fuel not being made into energy out the exhaust kind of like some bike oils are doing in the saws. The saws just do not have enough power nor generate enough heat to benefit from these fancy fuels and oils ????
Only way to know is compare different octanes in your saw with timed cuts.
Ron660
6:28 AM
NW Louisiana
Brian some dont understand the top and bottom capacities that r measured to derive the ratio r different in a saw compared to a vehicle with high psi. U cant use a baseline chart for a octane/psi chart for a car to compare to a saw not knowing your ratio and assuming it? I think it would be easy for someone to pull a octane/psi chart for a vehicle off the internet with 14to1 compression ratio to a saw @8to1 the chart wouldnt apply to a saw? And the chart surely doesnt work if u havent measured your ratio and guess? These work saws have too short of a stroke to have time to detonate and have any benefit from high octane
It's very simple. Test your ported saws with different octanes and that's your answer. Your mtronic saw was faster with higher octanes the same as mine was. Theorizing isn't going solve anything. Timed tests will.
Ron660
6:28 AM
NW Louisiana
I've seen a few pics of Klotz which black carbon on the piston past the rings.
