Stihl Backpack blowers
pbillyi69
1:54 PM
USA
I understand the frustration ect but it’s a dealership problem not Stihl and as mad as he is he really should say something to Stihl for everyone and I will talk to my friend. Stihl does reprimand dealerships that do stuff like this. This is a dealership issue and problem is if they did it to one they did it to more and all it does is make all the other dealerships and Stihl look bad. They can’t even use the pro use excuse because blowers have the same warranty pro or consumer.
so here is where i am. i called the only stihl shop that i would let work on anything. its an old school saw shop in a logging town. told him the whole story and that its registered to my friend he said bring it to him and he would fighre it out. i also told not to do any work that isnt covered by warranty that i would do it myself. he said no problem.
pbillyi69
1:54 PM
USA
Update. the shop called last week and said either tbe wrist pin or main bearing is tight and that it needs a new motor. So he ordered a new engine and replaced it under warranty. I got it back today and it runs great. I told my friend and asked him if he wanted it back. he was firm in his resolve and doesnt want anything to do with stihl. so i got a brand new br800 for free.
10:54 PM
You suck, Sir! :thumbsup:
pbillyi69
1:54 PM
USA
yes, yes I do. he gave the echo 9010 a few months ago that needed a carb. he put a cheap on off amazon and couldnt ever get it to run. i made that on run too. the cheap carb wont let it rev as high as it should. its about 500 rpms low but it still pretty strong
EFSM
3:54 PM
Extreme southern IL
Hopefully it’s not lean of peak.
pbillyi69
1:54 PM
USA
Is the aftermarket one adjustable on both the high and low like the original?
yes but the screws dont really feel like they have springs on them for tension.
pbillyi69
1:54 PM
USA
the original carb with the tiny D screws look to me like the heads are buggered up. if they are i may try to solder or epoxy extentions on them so i can just adjust them by hand. if thats even possible
legdelimber
4:54 PM
N.C.
Watch out on the needles/carb screws that don't have tension springs. If they cross drilled the screws and put a plastic chunk in the hole.
IF they don't deburr the cross hole and the needle/screw threads.
Un-screwing the needles rips out a lot the threads in the carb body holes.
There might still be some photos over on Arboristsite, in a thread about an Echo pb-500 blower, where I ran into the needles with the nylon inserts in the screws.
pbillyi69
1:54 PM
USA
thank you for the tip. the aftermarket carb is the one that feels like it doesnt have the springs. I will pay close attention to the factory car when i take the needles out if i can even get them out.
