Deets066
AKA Deetsey
- 7:33 PM
- Dec 28, 2015
- Illinois
That's one way to look at it.here is theory saws that use oil that have a lower viscosity and flash point will make better power than other oils that have a higher viscosity and flash point. as the oil that is burning with the gasoline will produce more BTU's than the other other that is not being burnt and left behind in the engine.
that is the way my little pea size brain understands this.
I look at it as a "good" oil will have more viscosity will have less piston and bearing wear. It will also provide a better seal with the rings, which means more compression and no blow by.
Less viscosity cheaper oil with lower flash point may burn hotter but may have some blow by. Black carbon burnt past the rings. Which means your not burning all the fuel you transferred from the case
