The SCARR Husqvarna 592XP build thread.
Glock37
12:09 AM
Monroeville Pa
When on lathe do u have too do all the way across base can you leave a 1/4 where impulse is since it dosnt mate to anything on case
srcarr52
12:09 AM
Iowa City
But the same distance out from the bore on the opposite side is in the transfer mounting surface.
kneedeepinsaws
10:09 PM
Oil Country
The stiff spring on the Schrader will cause the lower reading
Yes it will, the amount of psi it takes to open the spring is the amount lost on the reading :)
I believe it's about cooling the cylinder at its hottest point, the exhaust port with the incoming fuel/air charge.
Smart!
srcarr52
12:09 AM
Iowa City
Some pics of the 585 porting.
The exhaust port grew a fair amount. I use a mechanical pencil to trace the port onto the piston so I can validate the shape.
jk14
12:09 AM
Glenside Pa.
Comparing the cylinder, again 585 on the left.
All the ports look of similar shape and size (ratio to bore). The transfer lowers are pretty much identical, of course the bores are different sizes but so are the skirt extensions. So the 585 skirt extension is floating around in the case. Both exhaust ports have an identical wave pattern in the roof. The 585 intake port is rough cast while the 592 port is smooth like it's been machined. You can see the stock squish measured at 0.023" and 0.022".
View attachment 317015 View attachment 317014 View attachment 317016 View attachment 317017
Did you post a pic of intake flange before machine work Shaun?
Nice work Man.
