- 8:34 AM
- Jan 12, 2016
- Iowa City
You could if you mill it it seems.
Setting these up on a mill would be pain.
When on lathe do u have too do all the way across base can you leave a 1/4 where impulse is since it dosnt mate to anything on case
did 592 and 585 come with 7 pin rim from factory
Don't you have one you could test? LolWhat was it stock?
I'm just playing with you, boss lol love ya budsMaybe......if I had a 10mm extended type gauge I trusted.
125-130 psi, they are abnormally low compression.
But the same distance out from the bore on the opposite side is in the transfer mounting surface.
Yes it will, the amount of psi it takes to open the spring is the amount lost on the readingThe stiff spring on the Schrader will cause the lower reading
Smart!I believe it's about cooling the cylinder at its hottest point, the exhaust port with the incoming fuel/air charge.
Comparing the cylinder, again 585 on the left.
All the ports look of similar shape and size (ratio to bore). The transfer lowers are pretty much identical, of course the bores are different sizes but so are the skirt extensions. So the 585 skirt extension is floating around in the case. Both exhaust ports have an identical wave pattern in the roof. The 585 intake port is rough cast while the 592 port is smooth like it's been machined. You can see the stock squish measured at 0.023" and 0.022".
View attachment 317015 View attachment 317014 View attachment 317016 View attachment 317017
Did you post a pic of intake flange before machine work Shaun?
Nice work Man.
Nice work Man.
It's because his reply is all quotes from other members, he didn't actually write anything that you could quote.Not sure why I cant quote Jeffs reply but thank you.
Optical illusion I believe. Camera angle vs near/far type thingIt looks like the strato ports are wider then the tract of the intake width?View attachment 319372
