The SCARR Husqvarna 592XP build thread.
srcarr52
5:46 PM
Iowa City
My experience with the hf set was the schrader valve was garbage. Ymmv
Don’t go wasting your money on the HF kit. The Schrader valve is behind the quick coupler. Fricken dumb! I guess off to the lathe to put a Schrader valve in the hose end.
4:46 PM
For folks to know, the Echo tool seems good in quality, that particular piece is stamped USA.
srcarr52
5:46 PM
Iowa City
So I modified the compression tester adapter so it now has a Schrader valve.
Before, without it's own Schrader it would read 110psi on the 592. Now it reads 130psi, which seems low but it might be legit. I'll have to measure the combustion chamber volume and knowing the trapped volume above the exhaust port I can calculate the ideal compression pressure.
srcarr52
5:46 PM
Iowa City
The stiff spring on the Schrader will cause the lower reading
They won’t hardly read at all. I tried one and with no gauge on it I could hardly get it to pop off and let any air out. To get proper readings I stole the valve core from the tester. I ordered 6 low pressure ones.
thinair
2:46 PM
B.C Canada
I didn't get the large kit but got the Echo 91147, and so far, I'm really happy with it.
ferris
11:46 PM
Germany
I won’t believe that say rev over 13k.
The manufacturer reduce the max rev for the 90cc saws about 12,5-13 in the past. 13.5 would be really high
