T.Roller
- 3:23 PM
- May 11, 2016
- Southeast, TN
Thank you
Thank you
I have a couple from them.Those in the pic I made on my lathe .Kevin,Cut -for-fun made some from square nuts using a file and they worked just dandy .
Baileys at one time sold them for using Stihl bars on Huqvarnas but since I no longer patronize them I have no idea if they still carry these items .
MattD ,Those filters are not that easy to find and they get a pretty penny for them even used .Scott at chainsawr lists one for about 25 bucks .Obviously you can run them without bar plates ,those are where you find them .Might be e-bay or from a dead one in the pile of dead saws that most dealers have .Scott may have a set or two ,give him a call or drop an e-mail because he has tons of stuff he doesn't get listed on his site .He will find them and drop you a line when he does .
On the 10 Series bar plates, they are the same as the outside plate used in 600 series saws.
Mark
I have used the nicopp brake line to make spacers for a few different saws, I use that because it forms around the stud and stays tight.A thought occured to me just now,a light bulb went off .I wonder if a little piece of hydraulic tubing would suffice for a spacer .
When I get a chance I'll take a walk about at work with a 3/8" fine thread bolt to check ID and a set of micrometers to check OD and see what I can find .---this could be
'uge .--alas the junk yard dawg just keeps rearing it's ugly head ---
So if I'm understanding correctly an outside bar plate from a 600 series saw will fit the 10-10 on the inside and outside?
A thought occurred to me just now,a light bulb went off .I wonder if a little piece of hydraulic tubing would suffice for a spacer .
