lehman live edge slab
Live Action
1:37 AM
Mn
On a local auction, what model is it because no pics of bottom. 1-50 series? I think I have a problem haha 😂
Live Action
1:37 AM
Mn
If it is original it is a 1-50, they were the only ones with that starter housing left over from the D-30/36 and the full wrap bar.
Mark
That’s what I was guessing after some more research, so are they worth buying? I’m assuming it’s 80 cc still like a 1-40 of the same era but maybe actually had full bearings and a third port induction vs the bushed 2 port 1-40. I’m assuming this will make it have a fair bit better power?
heimannm
1:37 AM
Dike, Iowa
I'm not sure if the 1-50 had the third exhaust port opened up or not...some of the 80cc models only had 2 of the 3 opened, maybe they are all that way I just don't remember. The 87cc models had all 3 ports opened.
Mark
Live Action
1:37 AM
Mn
Mark
Well if I get it maybe I’ll have to look, don’t need to had one on eBay for sale and this is what it looks like.
heimannm
1:37 AM
Dike, Iowa
In my mind's eye I thought I remembered only 2 or 3 exhausts ports opened, but looking at a few blocks in the attic I see it is the intake on a few. May be the MAC15 only had 2 exhaust ports opened...?
Mark
Live Action
1:37 AM
Mn
Put a rope in the 1-71 and it has spark put a little gas in it and it popped I’ll still be vac/pressure testing but was curious if it had spark. Got the 10-10 automatic rewind repaired and it runs well but did rev up slightly higher when tipped into felling position bus stayed running but I’m thinking I may put seals in that also. I’m assuming the 10 series saws all use the same seal set? So I can order like a half dozen and just change them all?
Live Action
1:37 AM
Mn
McCulloch 1-40 looks like 2 intake and 2 exhaust so probably be less than a 1-50.
heimannm
1:37 AM
Dike, Iowa
The 54 and 57cc models use the same seals as the 600 Series, 67096 on the FW side and 110260 on the PTO side. FY side seal sits beside the 67905 bearing.
The larger displacement 10 Series saws use 61618 on the FW side, presses into the wide outer race of the 63429 bearing.
Mark
Member
1:37 AM
Just received a goody in the mail today, a wall chart from McCulloch circa 1977 on all the testing methods and specifications for the use of a Merc-O-tronic 88 and 98 ignition testers on point type ignitions. This not only broadens the field of use, it also simplifies into four groups by model. No part number is needed to test now, the point type anyways. Also does condenser testing as well.
Modulated coils have to be tested on a different tester so as not to fry the module. Those I'm still down to listings by part number to be tested.
hacskaroly
2100 Fanclub Member
11:37 PM
Northern Idaho, Ehh
I am faced with overwhelming opportunities...
If I had the funds available, I might have gotten it. I really like older test equipment. Years ago, I bought a Tektronix 555 o-scope with several interchangeable modules. I even bought a Tektronix square wave generator so I could calibrate it. Tube equipment is fun to work with!
Live Action
1:37 AM
Mn
Well the 10-10 super needs full tear down but has good spark just a real rough spot in stroke even with plug out. The 5-10 will run well had good spark and started need ro get some seals and at least a carb kit . Trying to decide if I should part out the super 10-10 for carb and stuff or keep as is buy parts I need and fix the 10-10 super later. Im sure tank would fit but looks divided different for air filter and its yellow instead of black so kinda want it to look like it’s supposed to.
