- 7:05 AM
- Jan 28, 2016
- Dike, Iowa
My feeling was a 16 is the better bar for it. I can do without brake assembly but would definitely like to have it. Bar, clutch cover (preferably ProMac and yellow with chain tensioner) and a fuel cap are what I'm after most.I prefer a 16" on the 10-10 models, maybe 18" on a PM55 or 10-10S version. I have everything you need except the clutch cover/brake assembly and I may have a decent used one of those; I will try to remember and look next time I'm up in the attic.
Real men run 10-10s that didn't come with a chain brake...that is what hard hats are for!!I can do without brake assembly but would definitely like to have it.
Maaaan, only reason I wear a hard hat is because my only ear pro is hanging off the back of it!Real men run 10-10s that didn't come with a chain brake...that is what hard hats are for!!
Glad the saw showed up, they are a lot of fun to work on. I wilr filter I got, since it won't fit on my saws and send it.
Is the coil contacts clean and rust free? Does the flywheel have rust/dirt on its surface? I would double check the wiring to make sure there aren't any shorts against the case or a loose wire somewhere. Carb gaskets look good, not crunchy or dirty inside?Spark comes and goes.
I haven't turned one bolt on it yet. Figured I'd start with the switch and move down from there and check all those usual suspects you mentioned.Is the coil contacts clean and rust free? Does the flywheel have rust/dirt on its surface? I would double check the wiring to make sure there aren't any shorts against the case or a loose wire somewhere. Carb gaskets look good, not crunchy or dirty inside?
The recoil looks like it needs to be cleaned out and then it should suck the pull cord all the way back in.
I would not have been that patient...I would have had the saw apart and spread across my workbench withing 10 minutes of it arriving...lolI haven't turned one bolt on it yet. Figured I'd start with the switch and move down from there and check all those usual suspects you mentioned.
Oh, don't think that ain't what I want to do. I'm trying real hard to have a little self control with this one. For a change I want to see how little I can do to get it running, then rebuild it from the ground up. I've got one saw pulled apart, don't have space for another.I would not have been that patient...I would have had the saw apart and spread across my workbench withing 10 minutes of it arriving...lol
I have four of my own saws pulled apart and 6 that belong to others. Dollar store baskets are very handy to help keep things separate and organized!!I've got one saw pulled apart, don't have space for another.
Organization of any way, shape or form is not in my DNA.I have four of my own saws pulled apart and 6 that belong to others. Dollar store baskets are very handy to help keep things separate and organized!!
