edju1958
- 11:43 AM
- May 23, 2018
- Western N.Y.
I bought this PM650 back a couple of weeks ago for $88 (a steal IMO).The seller knew nothing about it,so I took a chance.I got the saw & put a new fuel filter on it & a few pulls later it was running like a champ.The carb was way out of tune & got that situated.I went to shut it off & it didn't.I pulled the recoil/fan housing off & found the ignition wire had pulled out of the connector on the switch.I put a new connector on the wire & the switch worked as it should.I noticed that one of the screws that holds the fan housing/fuel tank on was broken off in the oil tank & another screw had been replaced by an oversized screw that had wallowed out the boss.I found another oil tank in my garage & replaced the damaged oil tank the other day.When I pulled the clutch off I noticed that it came off very easily & the thrust washer behind the clutch was missing.I lubed the needle bearing & put it al;l together & went to put a bar & chain on it & it wouldn't tighten the chaion at all.I pulled the newly added chain brake off that I had on hand from a Timber Bear (I really don't like the flag style chain brakes).Upon further investigation I found the adjuster pin was folded in half & was broken.I had to pull the clutch & cylinder jacket off again & replace the adjuster pin with the original screw assembly that was on the saw.All back together again with the bar & chain.The saw fired right back up again & it seems to be oiling as it should
