edju1958
- 9:46 AM
- May 23, 2018
- Western N.Y.
Today I got the throttle handle that I bought on Feebay.So,I thought that maybe I could get the 4th saw running in as many days.I put the throttle handle on the saw & found that the throttle lock didn't work - the lever was broken up on the underside.I figured I could jam something in between the throttle rod & the back of the carb box to act like a throttle lock.A 5/16 deep well socket fit the bill perfectly.I put my 2nd last Walbro carb on the saw (I found another Walbro yesterday) that was supposed to be good as it held pressure.The carb turned out to be crap as it wouldn't pull fuel.I pulled the recoil off to make sure the fuel line wasn't kinked & I noticed that this saw was a late model saw.It had the weird torx screws instead of the regular slot head screws & the same was in the air box.I also noticed that this saw had no sawdust on the engine anywhere.This saw is brand new & has never seen wood! Now if I could only get this bugger to run,Lol.I've got a couple of Walbro carbs coming from Mark H.,but I'd like to try to get it running sooner.I can't remember wherer I picked this saw up.
