Maintenance Chief
- 7:19 PM
- Jan 4, 2020
- South Carolina
I bought this 2-10 last month from a seller on Feebay who has tried to pull shenanigans with me in the past.Everyone thinks he's an "honest guy",but I beg to differ.There wasn't much to the saw to begin with,missing the entire right side - no clutch,starter,muffler,etc.The front handle had been "spliced" (I sure as hell would never use it).The piston &cyl.look decent,no scoring.I tore the saw apart yesterday & cleaned it somewhat.I went to put it away & just happened to notice that the keyway for the clutch is pretty well buggered.I've been told that a Woodruff key isn't necessary as long as the clutch is torqued appropriately.I tried to get a pic that'd show the imperfection on the crankshaft,but it doesn't really show up that well.The imperfection is on the right side.There should be a "wall" where the key rests against,that wall is pretty much gone.Other than replacing the crankshaft I don't think this engine is any good anymore.
The other thing I'm having problems with is the automatic oil pump.The piston was stuck & I had a helluva time getting it freed up.I finally got it out of the pump body & had to lightly sand with croakus cloth on the outer edge of the piston & on the inside edge of the pump body.It works freely now,but every now & then it'll get stuck in the down position & it still doesn't pump oil.I put a couple drops of oil on the intake side of the pump & worked the piston.Normally that oil will be pumped to the exit side of the pump.I took the bottom screw out of the pump body & found a small spring attached to the cover.According to an IPL there should be a small check valve ball in there,but nothing came out.I plan on running the pump through my ultrasonic cleaner to see if it'll free up the check valve.View attachment 323829
Just put the key in it with a dab of lock tight on it and let her rip! It'll be fine Ed .
As Mark said dont put a rattle gun on it though, hand tightened only those dog gone things shatter if you start hammering them.
I've gotten saws that have run that way for years.
