Woodslasher
Teh debil
- 11:32 PM
- Mar 18, 2021
- Commiefornia
So, I received my chain brake assembly the other day and the bar adjuster is on the cover...the power mac 6 adjuster is part of the oil tank. Not sure where the outer bar spacer would go either. Am I missing something here?The actual cover looks exactly like mine so I'd guess it's the same. Don't take my word for it though. Here's a sold ebay listing showing the cover, if that helps any.
I have a few mac centric questions for the experts as I try to get back to my big boy saw projects.
Will an MC91 and 795 fan cover interchange?
Are there any tricks or preferred methods to removing the clutch and flywheel from a 795?
As I move forward on the MAC obsessive journey are there any tools I should grab for working on the larger saws?
I am currently completely tearing down the 795, I really like the looks of it over a 125 honestly.
I want to make sure I am familiar with what is involved before stripping down the NOS 101B on camera
Current build plan - mostly 795 chassis, full wrap, all custom powder coating with three inter-changeable air filter covers, bored, ported 125 cylinder at 61.5mm bore, nikasil platted with Wiseco 61.5mm CCCR piston, billet full circle turbo crank stroked 4mm, V12 intake with Tillotson billet race carb (model as yet undecided), lightened flywheel (no fins), leveling kickstand, dual decomps, no dogs, left hand start, clearanced clutch cover to fit 15 or 16 pin rim, CCC Racing by Cannon custom racing bar with 72DL square 3/8" .050 chain, upright spring mounted pipe, woven custom rear and recoil handles, and a few surprises
It won't be done quickly, but it should reach the finish line in no time flat.
Dave
Dave
Hmm, I'd swear my tensioner is on the cover, and despite the fact that my saw is wearing a (the original?) Mac b/c it is completely devoid of any bar plates.So, I received my chain brake assembly the other day and the bar adjuster is on the cover...the power mac 6 adjuster is part of the oil tank. Not sure where the outer bar spacer would go either. Am I missing something here?
Thanks Mark! Good to know. I have a question about a 2-10. Would you happen to know the year serial number 12-138042 was built. I went to acres site and it gives a couple year range. I was just wondering if anyone can narrow it down further.The older PM6 saws had the adjuster in the oil tank. Later ones, with a brake, had the adjuster in the clutch cover. You can use either one (but only one) if you put the later clutch cover on an earlier saw.
In fact, the oil tank on the later saws could not even be modified to accept the adjusting screw as they changed the design of the casting.
Mark
Cool build! 150cc! Nice, the Stroker crank Will really wake up the 125, and allow you to set up a good squish, like that! Where did you get the crank?I have a few mac centric questions for the experts as I try to get back to my big boy saw projects.
Dave
They are supposed to be 1/4" 20 .However for whatever reason on one of mine they were #12 -24 I think .They obviously would not hold and I tapped them out to 5/16" -18 .Let me just say pulling a flywheel from a 125 is not all that easy . If I ever need to pull another I'll heat the flange first .As JJ noted, the threads in the flywheel are 1/4-20, it is a good idea to leave the nut on the crankshaft (backed off a few turns) with using a puller as the flywheels will occasionally become UFOs when they pop off. There are also two 1/4-20 tapped holes in the crankcase cover to facilitate opening the crankcase.
Mark
Roger that. Thank you!Jeff - Best I can do is between 1969 and 1974 with the 12- prefix. My guess is closer to 1974 based on the high serial number.
Mark
