fossil
- 1:24 AM
- Jan 1, 2016
- Ontario, Canada
All the best to your wife's recovery Mark.
Seems close but still a bit fat.How does this sound for tuning?
Glad to hear she is recovering Mark!! Hope she continues to heal well, and quickly.Still trying to play catch up. Mrs. remains in the hospital but is becoming more cantankerous every day...I guess that is a good sign. She may be released tomorrow or Wednesday, then I will have to stay close to home as she it still pretty weak.
Mark
Tough week this week, Mrs. Heimann was admitted to the hospital on Monday and will be there another day or two at least. On the mend now but it will continue to be slow going for a while.
That felt in the oil pump is called "Pad, Pump" in the IPL's, many of the IPL's show it and it is quite often missing. I am not sure what the purpose is.
My 640 WOT out of the wood. It was a little lean but not really screaming for mercy.
The Magnificent Seven The DE50 is mostly McCulloch ("built in an Italian McCulloch factory"), the others are Dolmars.
Good to see Aaron posting again.
Mark
Ditto. It's good to see him posting anywhere again. Let's try to not scare him off.
And all the best to Mrs. Heimannm for a quick recovery.
Mark
No idea where the points are set there is a .012 written on the handle ?? Set saw by ear still need to put a tach on it.It’s sounds good under load. And it’s not crazy fat. Did you set the rpm with a tac? What are your points set at?
I would check the points, should be.018-.021, if it is at .012 it will wake her up.No idea where the points are set there is a .012 written on the handle ?? Set saw by ear still need to put a tach on it.
All I know is LeeHa built the saw I don't plan on touching anything inside unless something breaks. I hear he is a guru when it comes to these.I would check the points, should be.018-.021, if it is at .012 it will wake her up.
