- 6:38 PM
- Dec 26, 2015
- The land of pleasant living
I just put a 42 Special together but didnt pull the clutch.
Hope you had a Merry xmas Tor!The one to left in post #4 is the last version.
I think Oregon is phasing out 242 clutch drums.
If you have the oil drive with the slots,
the clutch drum you should have is Oregon 40068, Husqvarna's part number is 501.63.66.05.
You can of course go back in time, but I think it's about as hard to find parts then too.
If so, then it's Oregon 29105, you need washer, and the drive was the same one used on 133/234/238/44 and 444, was available in both plastic and bronze.
I definitely had that, putting together parts for the projects that will be started soon.Hope you had a Merry xmas Tor!
They had three oil pumps, v1, v2, v3, but unfortunately with only one part number.I have the Husqvarna work gear puller. What I don't know is I the worm gear is compatible with the oil pump that is on the saw. Anyone know?
Welcome to the forum Harald! It looks like this site has a bearing that should work on the PTO side of the 42.I have read through this thread, and how I understand it, there is no PTO side bearing obtainable for this chainsaw, is that correct?
Thank you! I thought it was tested by others on this thread and that it is leaking air? Or was that a different bearing?Welcome to the forum Harald! It looks like this site has a bearing that should work on the PTO side of the 42.
Duke's Saw Shop - Husqvarna 42 PTO Bearing Page Link
Hi Harald and welcome to OPE.Hi, I'm new to this group, I live in Norway and find it very meaningful to repair chainsaws. Because of this I have an old Husqvarna 42. I believe it is from 1990. I originally thought I could use SKF 6201/C3 bearing on both flywheel and PTO side. I understand from what you write that SKF 6201 does not work on PTO side, I believe the reason is that the oil seal will not fit on the SKF 6201? I have read through this thread, and how I understand it, there is no PTO side bearing obtainable for this chainsaw, is that correct? Regards Harald
I don't know if they have been tested and leak.Thank you! I thought it was tested by others on this thread and that it is leaking air? Or was that a different bearing?
That I don't know, if I had a 42 I would give it a try unless you can find a parts saw and can take the existing bearing off of it to use (if it was still good).hank you! I thought it was tested by others on this thread and that it is leaking air? Or was that a different bearing?
I think I may have been the start of that project, it is based on using a bearing with the same inner diameter, but narrower and smaller outer diameter than a 6201 bearing has in terms of dimensions.At Magnus, someone showed how to convert the original bearing into a different one
Well I finally got around to popping a seal out of the @Duke Thieroff bearing to see if an oem seal will fit. Unfortunately, the oem seal has a smaller o.d. and smaller i.d. than the seal that came with the Duke's bearing, so the oem seal is a no-go in this situation.
