lehman live edge slab
Live Action
- 12:44 AM
- Sep 2, 2017
- Mn
NoIs M-Tronic and Intellicarb the same thing?
I'm too deaf. Tach for me.Limited can be done by ear in wood, if done from a rich condition where it is four stroking while cutting. Start leaning it out until it just cleans up while cutting and you have it. This way you get it done before the coil cuts out which confuses the situation by tach or ear if done from a lean condition.
I like turtles.Is M-Tronic and Intellicarb the same thing?
The intellicarb is just a standard manually tuned carburetor, which is designed to compensate for a restricted air filter.Is the Intellicarb part of the M-Tronic system?
Yea it can.I used to set engines by tachometer. However, that cannot take into account a worn or extra-well made engine. I think if you know what you're doing, tuning by ear cannot be beaten.
I try not to stick the chain in the dirt too often.Yea it can.
What i do with saws is use the factory no load rpm as a starting point. I then adjust until I get peak performance in the wood using cut and feel method. I then take a tach reading and record it. Fron there i can tune repeatedly to that optimal set point.
Factually incorrect... if you are tuning your saw for the best performance in the cut, 10-15°F can be the difference of about 2-3000 rpm in the cut (speaking from experience with my 026, ms362, and 044)Absolutely true. Unless you only use them twice a year, once when it's 0* and then 6 months later when it's 90*.
I tune my 024 to 13,000 in the dirt. Then piss rev it to 17,000. The Inteli-Tronic will rev limit it back.I try not to stick the chain in the dirt too often.
I like turtles.
Both are tasty.I like bunny rabbits.
I find this hard to believe, although I have more experience with other saws. If the 10-15 degree difference is also the difference between frozen and thawed wood, then maybe it's believable.Factually incorrect... if you are tuning your saw for the best performance in the cut, 10-15°F can be the difference of about 2-3000 rpm in the cut (speaking from experience with my 026, ms362, and 044)
He is correct.... listen, you might learn something.I find this hard to believe, although I have more experience with other saws. If the 10-15 degree difference is also the difference between frozen and thawed wood, then maybe it's believable.
Has nothing to do with saw brand, an ideal mixture is an ideal mixture doesn’t care what saw it’s in. That is the job of the carburetor, mixes the gas and air in proper amounts for efficient combustion and most power saw brand won’t change that.I find this hard to believe, although I have more experience with other saws. If the 10-15 degree difference is also the difference between frozen and thawed wood, then maybe it's believable.
If you dont see a performance difference with a 10-15° temp change with your tune, you are leaving power on the table.... simple as that... even a 20% humidity change at the same temp can cause power loss due to the dynamic air quality,and how oxygen dense the air is....I find this hard to believe, although I have more experience with other saws. If the 10-15 degree difference is also the difference between frozen and thawed wood, then maybe it's believable.
Well, we have a weather change coming up. I think I'm gonna take a tach out today and then after it gets colder and either prove myself wrong or right. I'm not disagreeing with your point. I just can't believe the difference is 2-3 grand in the cut. That's like 30-50% power difference.If you dont see a performance difference with a 10-15° temp change with your tune, you are leaving power on the table.... simple as that... even a 20% humidity change at the same temp can cause power loss due to the dynamic air quality,and how oxygen dense the air is....
