Stihl 1125 (034/034S/036/360) Cylinder/Saw ID
10/80
3:17 AM
Are the 034 Super and 036 cylinders internally the same?....EG port layout, combustion chamber shape, etc?
Cracker Boy
Fl cracker
1:17 PM
Florida
They are both 48 mm but with a super cylinder and a 036 muffler it requires a spacer between muffler and cylinder. That is unless you have the 034 muffler or 034s muffler Wich is one with the holes in cover like an 026 muffler Everyone wants the 034s cylinder as they say the timing numbers are better.
Cracker Boy
Fl cracker
1:17 PM
Florida
So internally the 034 Super & the 036 are different ?
No not really same bore same crank same crankcase. The 034s .Were non compinsator carbs they had tillotsen carbs instead of same in most cases 034s were non decomp cylinders unlike the 036 pro with decomp
Cracker Boy
Fl cracker
1:17 PM
Florida
034s and 036 have different intake and exhaust ports.
There are some differences thats why 034s is so desired. For example a 044 10 mm slant fin from a ks to a major are diff. I have 2 066 non decomp major cylinders one the intake was 1 mm lower. You just never know till you put a timing wheel on them
1:17 PM
Whats this major cylinder you are referring to Brian???
1:17 PM
I wonder why Stihl ever changed the design then???
1:17 PM
Ahhh. OK. That makes more sense. TY
BuckthornBonnie
1:17 PM
Penn Yan, NY
Agreed. The 064-660 transition I almost “get” due to the poly flywheel, oil pump differences, bigger crank and p/c, but still... those early 1122s are a blast to run.
The 1125s have the same crank, bearings, cases, oil pumps, etc. The p/c, air filter setups, and a few items are different from 034-MS360. I’m assuming EPA and engineering differences expedite change... doesn’t mean I have to like it.
