Stihl 1125 (034/036) Oil Pump Oddity
6:23 PM
I’m fixing up an 034 for a buddy and I have now found a 3rd rendition of the oil pump for the model. I wanted him to have a side adjust case and knew I had an extra 036 case lying around.
The usual oil pump is the 1/4 turn cam adjust type we all know.
The last oddity I’ve seen until now was an old 034S pump with a slotted screw to adjust which made multiple revolutions and bottomed out on the case. Seemed to be the highest output pump.
I found this unfortunately yesterday. A pump with no adjustment on a case without an adjustment hole. I have to grind a slot in the case to actually fit the adjustable pump on it as well as bring the rail to access the screw. The case lacked the extra webbing around the adjust hole as well. Seem like it should hold up.
Very odd indeed. Figured I’d share.
7227A4A8-280D-45D8-BEA3-2EF7C8D72F25.jpeg 52AAF349-5898-4609-B126-1D76B3B2955A.jpeg 68DDB860-078E-4C97-8D17-72B5996A4A2B.jpeg D4466D9D-5F2B-446D-ACB0-83B927AAEF67.jpeg 5E0CBE22-E121-4121-85BD-C878D0CDB7E5.jpeg
6:23 PM
I haven’t checked the SN. I can post it in a bit.
I thought about an early case also, but any 034 early cases I’ve seen are front adjust. The late standard 034 and the 034Super were side adjust. All 036 are side adjust.
I know there was an economy model of the saw (036) with a plastic clutch cover, this must be one of those cases.
Hundred Acre Wood
Full-time Slacker
6:23 PM
On the hill
My 034 is front adjust and it came with a plastic clutch cover when I bought it new. Still have it.
Sawyer94
6:23 PM
California
