- 10:14 AM
- Aug 17, 2020
- Neenah Wisconsin
Thanks Al! This one has a WT22 on it…I thought it was supposed to have a Tillotson carb on it, so maybe this was a replacement at some point.Nice Job Greg. I’ve never done a standard 024. I’m assuming it has the WT55 carb?
If you need a metal AF for it, let me know.
I have heard they can scream. I am hoping to give this some more useable power by lowering the exhaust and shortening the blowdown a bunch.I didn't see it myself but some have mentioned a pair of 024's at a GTG .Those things ran at over 20,000 RPM's.What had been done them I never heard but they didn't fly apart like a dollar watch .In stock form for only 42 cc's they do okay for light work but they aren't oak slayers .
#grubbyoldpieceofstringftfwAnd here is what happens when you use a piston stop to re-tighten the flywheel nut on a domed piston that was cut flat. View attachment 383663
I would try to measure the Meteor and see if it might have more material in that area. If it does, then maybe give it a go?So, now I wait for a replacement meteor to come. I think I might leave the center portion of the piston uncut this time to leave more material…kinda hate pop ups, but not sure what else to do.
I think the flat top would have been fine in run, but using the piston stop was a bad idea. I will measure the meteor anyway.I would try to measure the Meteor and see if it might have more material in that area. If it does, then maybe give it a go?
It should have, but measure anyhow.I think the flat top would have been fine in run, but using the piston stop was a bad idea. I will measure the meteor anyway.
Yeah, I measured it with a straight edge and my caliper...the middle of the crown was right at .100" thick. Probably would have been fine if I had used some rope as a piston stop instead of a screw-in type.It should have, but measure anyhow.
Did you measure this one before it broke?
Meteors seem to be a harder alloy than oem. You can also take a little less off the top of the dome and leave a rolled edge at the crown/skirt interface. Wont do anything bad, just sand the difference from the band. A true .015 squish is safe in these saws.
A meteor 026 piston measures around .008 thick at the center of the crown when I’m done with it. Never had one fail, even at 275 psi of compression.
