So what did you do today?
Duce
7:19 PM
Roscommon, MI
I put some casters on my bench so It would be easier to move around. Now I can get back to cleaning out the garage.:(
Nice vise, I got tired of breaking them and purchased one, brother took the one when stepfather passed. Cheap, about same price as a new 550mk2.
Ronie
7:19 PM
NC
Thanks, I got that one at an estate sale last summer.
hoskvarna
6:19 PM
Iowa
Going to get a burl tree turned out to be a bad idea…
You need some tracks
Sent from Hoskey hilltop
Ronie
7:19 PM
NC
Milled a few thin boards today for the inside wall of my garage, to cheap to pay $40 a sheet for plywood, once I get that wall covered I can get my garage door on.
BlackCoffin
4:19 PM
Washington
Scored this behemoth. 178 year old fir struck by lightning. 53” on the base. About 155’ tall. About the biggest and oldest fir I’ve seen taken down in this area. There’s a few out there still I’ve seen, and all are plenty healthy still. Time to do some milling! Stihl 880 with a 50” bar hanging on one of the rounds.0FAAA976-2E2B-41E7-BA6D-590A7B166CB0.jpeg85966C58-F7E2-47C6-9917-B2C929F1CD6A.jpeg 2F18A576-DD45-4278-BD60-E363C56C9899.jpegB320B64C-CFF5-45AB-93D4-80F2FDEFEC05.jpeg3A897B84-328A-4D3C-A064-6AC8710BD3D2.jpeg
WillG
7:19 PM
Norwich CT
Got up early, went to breakfast, got the escape serviced, went to Napa and picked up a case of brake cleaner and 2 cases of 10w30 oil for my spring jobs. Did some tinkering in the garage and now I'm relaxing.
Stem
Professional Cup Stacker
7:19 PM
Pennsylvania
20220409_191714.jpg 20220411_004401.jpg 20220411_004417.jpg 20220411_004550.jpg
yesterday I got the new exhaust setup welded up & painted with VHT header paint. put the new boom cylinders & a couple new hoses on, drained the hydraulic system & put 9 gallons worth of new fluid in.
tonight I fabbed up a new throttle/choke mount, put the new cables on then started tidying up & looming the wiring for the lights & seat safety switch. gonna work on the engine bay wiring tomorrow. after that it's gonna get pressure washed & put to use this week while I'm off.
hoskvarna
6:19 PM
Iowa
View attachment 333179 View attachment 333180 View attachment 333181 View attachment 333182
Looking good
Custom dual exhaust and everything else gonna be a little hot rod [emoji6]
Stem
7:19 PM
Pennsylvania
Looking good
some reasoning behind that hot rod exhaust, with the huge factory predator single outlet muffler (which I believe has a cat in it) & such a small space it would boil the gas & usually geyser out of the fill cap. so this is attempt number 1 to prevent that.
If it still happens, I have a 6" electric transmission cooler fan I can put in the left side of the engine bay. I may also add some vents to the top cover/panel to help get the heat out. I might(should) make a shroud to cover the tops of the mufflers.
like any skidloader, the engine bay is literally 10lbs of sht in a 5lb bag, lol.
