- 7:43 PM
- Dec 29, 2015
- Ontario, Canada
I'm a slacker sometimes
I got that snowblower working this after noon. Its missing a gasket between the carb and the manifold. It idled good with choke on a bit and after half throttle ran with choke off. Sure it will run fine once i get a manifold gasket for it.I went thru a couple of coils trying to fix one of those engines, pretty common bad coil, last one I had it would start cold,, then as it warmed *s-word would start happening,, new used coil was the answer,, it had me stumped for a bit, though it was the carby as it sat for a long while outside.
Keep us posted.
BBB
Congrats Custer. Glad everything went smoothly for you and the MrsHey mike, shes pretty beat up, but this little fella is already a lot better sleeper than our other son. He slept almost continuously from 4 am until 9!! So mom amd i are both feeling considerably fresher than yesterday
See if you can find any info on the pump. Should tell how many GPM. You might have to go to a bigger pump to decrease cycle time.Bought a Prince 20 ton, 32" ram, 9hp briggs Log splitter
Carb issues, leaking hydro. Hose connection.
Runs and splits! But slow...
@ How do you speed up the ram?
Pump / idle speed?
*(processor plans underway!
*4 way wings, 'owl approved',
* table,
*an extension receiver
off the back to spin
this situation around. The splits will be on the back then!
Williams pump, PrinceSee if you can find any info on the pump. Should tell how many GPM. You might have to go to a bigger pump to decrease cycle time.
