RIChevy 026 build
paragonbuilder
12:17 PM
Norwich, CT
So lowering (raising towards the carb) the metering lever will help?
Please explain how this physically works. My understanding is that the diaphragm is pulled up by a lack of fuel in the metering side of the carb and not vacuum. Just wondering what effect it will have and why.
@Terry Syd
I remember he explained it but I can't remember where or the details. I believe a stronger spring, or shims under the spring were how he said to do it.
Redfin
Meh...
12:17 PM
Central Pa
I'll do that this week and see how she runs next weekend.
I did something different on the ports this time. I want to compare this saw to my 024 with the 044 carb and 26 head before I ship it to Jeff.
My 194 had the same off idle delay. Tad more pressure solved it.
12:17 PM
Looking good Al. I should do more build threads but I forget about it until the saw is together and running usually.
I know. Slows me down too. There's a lot of grease marks on my iPad cover as well.
I have a ton more pics on my phone I didn't post. I sent Jeff a pic every step of the way.
I try to stop and take pics. It helps me to remember what I did as well.
It's worth it to make threads everyone can enjoy and learn from. Worth the effort IMHO
12:17 PM
You put more spring under the metering lever is how you raise the pop off pressure.
Probably should but I never have been much for build threads.I have a real limited time to build stuff in doesn't help. I really need to start on the Christmas saw. It's still disassembled unless I use the 2065 that's a runner here and put the 2165 together later for me.
12:17 PM
I asked Doc if he was going to do a muffler mod. He said yes. I asked if he was going to drill a few more holes in the baffle. He said No. Out comes the muffler with a big hole in the side and a Red97 deflector! Just completely blew me away. Doc went over and above what I thought was going to be done to this saw. He is truly a master craftsman. That is why owning a saw built by him will be an honor and a privilege.
12:17 PM
i have 2 saws he built and they run awesome you wont be disappointed
12:17 PM
I see some extra work on the upper transfers, you are getting there Al.
Machined flywheel? If so nice. How would a muffler modded 346 compare to this?
No way to know without a direct comparison. A well done 346 should beat this saw in a race. The platform is just better to start with. Huge ports and a big carb for a saw of its displacement.
Beating this saw in the woods in terms of "drivability" and reliability/endurance is another story. I'd put my money on the lowly 026.
