One more shootout discussion: 288xp vs 390xp
2:27 AM
image.jpegAnyone guess what cylinder this is? Bet no one knows right away :)
2:27 AM
I really been studying the 930 closely and it's pretty interesting saw. Seems to share no resemblance or parts to its distant cousin 288. I think the coil is one of the only interchangeable major parts.
2:27 AM
There's almost nothing that interchanges. Piston are common only to the 9xx series.
2:27 AM
Pretty cool piston they got on 930, full circle windowed. Mine ended up being the thick ring one, which is a good thing along with the non governed tilly carb. Compared the 930 cylinder to the 910 I got and ports are similar but much larger on 930. The 920 has a 288 style cylinder while the 10 and 30 are bottom fed. I smoothed the lip in the transfers of the 930 cylinder where they stuck a end mill in and converted 920 to 930 cylinders. I didn't port it as it ran good stock. They must have decent numbers from factory. I did delete base gasket though. Just wanted to see how far I can take it without porting and I don't want to mess up a rare saw.
2:27 AM
I think the 820/830 are same saw but 52mm instead of 54mm piston. Both 38mm stroke. I wonder how they run compared to the 9's ? Probably like comparing a 281 to a 288.
