dustinwilt68
Wilt Built Work Saws
- 4:19 PM
- Mar 8, 2016
- Southwest PA
Not saying they dnt make faster then a 288, but I just dnt think they can make a saw any funner to run.
I have 288s n a 390.Lighter, more power, inboard clutch, better a/v, and side chain tensioner. I'll take the 390.
There's almost nothing that interchanges. Piston are common only to the 9xx series.I really been studying the 930 closely and it's pretty interesting saw. Seems to share no resemblance or parts to its distant cousin 288. I think the coil is one of the only interchangeable major parts.
Already seems special to me with that dollar sign cast into itIt's a regular 288 kit. But I'm gonna do my best to make it special.
Pretty cool piston they got on 930, full circle windowed. Mine ended up being the thick ring one, which is a good thing along with the non governed tilly carb. Compared the 930 cylinder to the 910 I got and ports are similar but much larger on 930. The 920 has a 288 style cylinder while the 10 and 30 are bottom fed. I smoothed the lip in the transfers of the 930 cylinder where they stuck a end mill in and converted 920 to 930 cylinders. I didn't port it as it ran good stock. They must have decent numbers from factory. I did delete base gasket though. Just wanted to see how far I can take it without porting and I don't want to mess up a rare saw.There's almost nothing that interchanges. Piston are common only to the 9xx series.
