MS462 Design Changes
4:14 PM
We have one of the earlier MS462's at work and a new top end has been on order since early December of 2021.
So, I guess my question is will Stihl ever furnish one ? Or, since it is a tree service would paying $400 or whatever for me to rebuild it be a bad investment in a questionable reliability saw ?
I'm thinking of telling them we can't do it whether I can scrounge up a top end or not.
It banged hard enough I had to re-center the crank shaft. May just be a bad idea.
I think they’re fine as long as the rpm’s are kept down (sharp chain) and no piss revving. More oil will slow the skirt wear
ZeroJunk
4:14 PM
Browns Summit N.C.
Well, as luck would have it the kit did come in Tuesday. So, Stihl still has some somewhere. It runs fine. I hope to never see it again.
Orangeinthebarn
4:14 PM
Tennessee
Yes. They aren’t quite as jazzy.
I don’t mean that in a bad way. Just maybe a chance for a different recipe. Before, I could only port them 1 way because I refused to raise the exhaust on them to make them more peaky. Now we have options
Yeah I’ve noticed the earlier ones are rated 6 hp the new ones are 5.9. Maybe not enough to notice much but definitely some differences
Funky sawman
Pony Power
1:14 PM
North idaho
This time of year I help out at a local saw rebuild shop, on my bench are 11 ms462, older style, with cracked pistons, 3 of those also have stripped plug holes too. They are all waiting on cylinders. Sounds like they got 2 years of hard use out of them, all from a tree service company. Rest of the saws im rebuilding are 4 572xp bad crank bearings, and one ms440 in for restoration.
On the 462 subject, I actually see way more of those and 500i's come in that have stripped plug holes than cracked/broken pistons.
I would still own a early 462. But knowing what I know, I would just swap the piston out after a season of full time sawing. It appears that the crack is caused by wear, and excess piston skirt slap. Slapping skirts is my thing so there is that lol
Beto88
New OPE Member
10:14 PM
Bergamo
Buongiorno io il deviatore sotto pistone lo rotto per cui lo tirato via tutto .. potrei avere più prestazioni o meno secondo voi
3:14 PM
Molti di noi credono che sia lì per aiutare a raffreddare il cielo del pistone deviando l'aria in entrata nel pistone. Il funzionamento senza di esso può causare il surriscaldamento del pistone. Tuttavia, non credo che le prestazioni cambieranno.
farminkarman
I like the red & black ones
3:14 PM
Neenah Wisconsin
Since when did you pick up Italian?
farminkarman
3:14 PM
Neenah Wisconsin
I'm tempted to make up some wild story about how I just naturally understand Italian because my IQ is higher than Albert Einstein's, but the truth is that I used Google Translate.
That is a handy tool...I have to use it often as a couple of our converting lines were made in Italy....and my IQ isn't that high
Beto88
New OPE Member
10:14 PM
Bergamo
Perché vedendo il carter modello nuovo non lo ha
