Mastermind Meets The Dolmar 7900
les-or-more
4:56 AM
lisbon ny
I should add that's the only one I have built but it turned out nice. The customer loves it. When done I also got away with running shorter blowdown times than the 7910. I'm assuming that has to do with case volume. Hopefully mike Lee and randy have some train of thought on this. :)
Most would just opt for the 79cc, I fell into the 73cc is the only reason I have it.
skippy
Husqvarnas Sawyer
4:56 AM
Pennsylvania
I believe I ran your saw in Western Kentucky . it was pretty strong
Miller Mod Saws
Chainsaw Masseuse
3:56 AM
Ravenwood,MO
Randy here's the notes and watch out for. The 7310 jug you can't drop as far till it free ports. The exhaust is wider on a 7310 jug. Not relevant for a port job but this might be. The 7310 transfer tunnels are actually larger at the base and taper up to the the upper transfers. The 7910 are smaller at the base and almost have straight walls up to the the upper transfers. Both are the same size by the time they get to the upper transfers. But there maybe something behind them being bigger at the base and tapering up. Let your mind wonder my friend. Lol.
