Husqvarna 61 Build - 630 super / 162 closed port hybrid
slackinoff
3:25 AM
usa
I found a new project! I was watching this on ebay and when the seller unexpectedly shot me a very low private offer, I took it.
I like the white top, I like the metal brake flag, I don't like the open transfers and coarse thread clutch.
I don't know what direction I'm going to go yet, it's a non runner so I need to check everything out first.
Pics are from seller, I don't have my hands on the saw yet.
Northerner
4:25 AM
Alberta
Good reliable saws, they won’t break any records it always get the job done. Plus easy to work on.
slackinoff
3:25 AM
usa
I'd like to get this one running and possibly try my hand at porting to warm it up. I cleaned up and chamfered the ports on my 440 clone build, would be fun to go a bit further.
BlackCoffin
1:25 AM
Washington
we have a 51 or 61 at work (can’t remember exactly) and it’s on a post hole auger. Really cool setup actually. It sees daylight once every 2 years it seems. The dang thing always fires up and works just fine!
Wood Doctor
Edwin
3:25 AM
Omaha, Nebraska
I that picture its looks like the exhaust deflector is on backwards?
That's the OEM installation and I never modified it. Yes it does deflect the exhaust back but then another part of the muffler reflects forward. Seems to me that could be a power robber. I may try to flip it around and see what happens. OP may want to look his over as well.
Wood Doctor
Edwin
3:25 AM
Omaha, Nebraska
Unfortunately, you can't flip that zig-zag exhaust reflector around. It has a bend that prevents that. Likely Husqvarna did that on purpose. You would have to fabricate a new part in the shop so that the spark screen remains intact. That's not impossible, but it's not a piece of cake for most mechanics.
slackinoff
3:25 AM
usa
Saw is here along with the parts I purchassed from Ronie. He gave me a good deal on a clean 630 super cylinder (could be a 162, same cylinder) and nice white top cover. This cylinder (630 super/162) has the same bore as the 61 but is a closed port instead of open. This combo still fits under the original white top.
One day I might like to try a 272 cylinder and cut the original beat up white top a spot for the spark plug to clear.
One issue I noticed right out of the box is that the stop switch freely moves, that will have to be replaced.
I forgot that these came with a Tillotson HS163a OR a Walbro WS17a. I for some reason was only expecting to see a Tillotson.
I think the correct rebuild kit for these Walbros are a k10-ws ?
slackinoff
3:25 AM
usa
Also its missing the single screw style airfilter, if anyone has one they want to sell, I'd buy.
slackinoff
3:25 AM
usa
Thanks @Ronie - I will send a PM
@David Young - thanks for the tip, I will give it a try.
Speaking of cleaning, thats the next step. I also want to see if I can get the white top a bit whiter with a magic eraser. I have the original busted one to test on which is good.
slackinoff
3:25 AM
usa
Having a hard time finding a kill switch for this saw. I'm thinking it's an older design, case grounded since the tangs are copper and I only see one wire going to it on my saw. What are my options here?
slackinoff
3:25 AM
usa
Btw I have the wrong ipl for this saw, I thought it was a 1979 but it's definitely not with a Walbro carb and this style switch....but the back of the switch looks broken, maybe it had two posts and I am missing a wire???
